I have a Kitchenaid KOSC504ESS wall oven and the display stopped working during a self-cleaning cycle. I assume that the issue is a blown fuse or bad thermostat, but the first issue is that I can't get the oven out of the wall. the screws holding the oven in place are behind a trip price and the trim piece can't be removed when the oven door is locked. I don't see a way to unlock the door. It is not wone of the old school ones where you throw a lever but instead, it has an automatic mechanical lock and I see no way of undoing it.
Does anyone have any idea how to manually unlock the door?
Thanks.
