Joined: 2/16/2020(UTC) Posts: 0  Location: New Hampshire
I have a Whirlpool Model WDT920SADM2, the Sensor and Heavy Cycles will not go thru the wash portion. I called in a repair person, he ran the diagnostics with no codes came up. I replaced the control board, that did not fix it. By process of elimination on my part, since 1 hr cycle works fine, i just replaced the turbidity sensor (figured that if 1 hr works). Powered up, ran reset on control board.
It still didn't wash on the sensor and heavy cycles. Any help would be great?
