AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Making Loud Consistent Low Pitch Whine
Hi, This is my first post here. I'm posting because I have no idea what to search for regarding this issue. Yesterday, my wife says she heard a crashing sound like broken glass then the dryer started making a consistent low pitched whine while running. Here's a link to a video clip (I only ran it for a couple of seconds): Dryer VideoIt doesn't make any sound when I manually spin the drum. I checked and it appears the belt is aligned correctly and it's obviously not the bearings on the rollers, if it doesn't make a sound when I manually rotate it (they seem to spin freely). I thought maybe it was the motor bearings, but once again, manually rotating the drum would've revealed that problem. Here's the make and model, Whirlpool LGR7646JQ0. Anyone have any ideas?
Dryer Repair
