mham99@gmail.com
#1 Posted : Sunday, February 2, 2020 7:30:26 AM(UTC)
mham99@gmail.com
United States
I had symptoms of no ice, replaced icemaker mechanism and still no ice.
When I removed the new icemaker part to check it out, I found that there were ice cubes jammed in the icemaker itself all frozen together. Appliance Parts Pros sent me another new icemaker thinking that first replacement part was bad.. I put it in, NG I then ordered and replaced the water valve mechanism and have same result - ice stuck. I chipped this batch out, put the icemaker back in, pushed reset button and got one good cycle - 7 cubes now back to no ice....
Any ideas?
<img src="https://putiqg.ch.files.1drv.com/y4mTMlmOZFIXN73ZMRXQ_P_LFJCLtBftSfUGCbab9lBCFgLzjTbpj68wk67CW8caMkOHP0PUvOMeZm9Dp6RRMxUFJLX1gVcUiwtRrFvvVia0bDpD1QVqPKXPf-qOrNRHNCOwjqX508bK4oC0HZn9S17nCykIYLOBnRC3HtTGz5o1bU7g1IaIL5TOENjlrvXdwSx7F0h0dqQmbgtk2KxyYBAUA?width=495&height=660&cropmode=none" width="495" height="660">Ice Stuck </img>
Edited by user Sunday, February 2, 2020 7:36:21 AM(UTC)  | Reason: Not specified
