AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool washer only agitates in one direction....(gsw9800pw2)
Joined: 1/25/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Georgia
It also makes a rather loud noise..The dogs need replacing but I can't see this is the issue with it only agitating in one direction. The splins seem to be fine on the bottom agitator.
This machine is 14-15 years old and has washed a ton of clothes...It's been a good one.
Does the capacitor in this direct drive model control this or am I looking at a new transmission/gear box....?
Brian
Joined: 8/26/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Delta, UT
We have a Whirlpool Cabrio washing machine that was making a horrible noise during the rinse cycle so I replaced the transmission and everything went together great. After the washer was hooked back up we did the recommended calibration as instructed but we still can't seem to run a load of laundry. In diagnostic mode the tank will fill, the tub will rotate one or two times and the water will drain but when we run a regular load the LED light never gets off the "sensing" mode. I don't have any idea what to do next, any suggestions?
Washer Repair
