AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Weak/gentle lower Agitation spins and drains (upper agitator fine)
Hi, do you guys think a transmission would fix a weak/slow agitator? i changed the clutch, motor coupler and got good agitator dogs and good threads on the agitator and the transmission shaft that connects to the agitator, the bell block is also fine but the agitator doest move much not enough to move the clothes, spins fine and drains the water fine but doesnt agitate with strong enough force to actually move the clothes but it does move slow and keeps turning... Please let me know if I should order a transsmision or something else like a motor or some electrical component to send more power to the agitator. thank you in advanced. JG PS. its a maytag washer MTW5870
Washer Repair
