Have an intermittent temperature issue with the oven.
Model: FPEH3077RFC
Occasionally, the oven will pre-heat and say it is at the correct temperature, but does not get up to temp. We have also seen it preheat appropriately, and then not hold the temp. (measured w/ analog i-oven thermometer)
Infuriating part is that is seems to be very intermittent.
Any ideas on how to troubleshoot greatly appreciated!
