I am using a Kenmore dishwasher model 665.13409N412. The machine will do nothing (but run the timer) on this cycle. If I restart the washer and change to Normal cycle, that will run, but does not open the soap dispenser and the dishes do not dry (there is finish in the dispenser. No repairs have been done on the machine to date (none have been needed). I have about concluded that the board is bad, but cannot find a way to confirm that. The number 13409N 582-1 is also on the doorsill label and Ser. F62011285. Any ideas?? Thanks
