krusen
#1 Posted : Thursday, January 2, 2020 7:56:09 PM(UTC)
krusen
United States
I have a 2015 vintage Kenmore model 796.41162410 front load washer that washes, drains and agitates fine, but when it tries to spin the excess water out of the clothes, it has an electrical hum for about 5 seconds and then throws an LE error on the screen. From what I can find on the web, it does not look like this model has any type of clutch assembly that might be slipping and there's no other unusual noises or smells that make me think a bearing is out.
I have checked the drain filter, and did not see any issue there (it is draining fine).
I'm not sure how to troubleshoot whether this is motor related, or control board. Since it agitates, with no unusual noise, I suspect the motor is fine.
Thoughts on things to look for?
