mike212
#1 Posted : Monday, December 23, 2019 5:00:59 PM(UTC)
mike212
United States
My Kitchen-Aid (KBFC42FSS00) refrigerator/freezer has been acting up recently. There is a beeping noise coming from the main control board which appears to be this part WPW10219463. The beeping is accompanied by a clicking noise that sounds like a switching noise. I've attached a video recording (mostly for the sounds - ignore my wife telling me we need a repair man :)).
Although the beeping is clearing coming from the round sound device on the control board and the clicking is coming from the board or something very close to the board, I'm not sure if the sounds are symptoms of an issue elsewhere or just a sign that the board needs repair. Unfortunately the boards are no longer manufactured so it will be a repair and we'll be without a fridge for some time so I'd rather not try that unless its very likely to be the issue.
The beeping/clicking can last for just for a minute or can last hours. Turning off the power and turning it back on after resting seems to offer reset the cycle for a while if its doing it for a long time. I have thoroughly cleaned out all dust from the entire area. The circuit board was already very clean.
Guest (5)
