AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Samsung Front Loader - Checking Shock Absorbers?
Joined: 12/3/2019(UTC) Posts: 0 Location: Pennsylvania
I'm trying to figure out why my WF419AAW washer is bouncing around and shutting down.
I've replaced the spider, and the basket is not out-of-round. The only other thing I can think of is the shock absorbers. They SEEM to be okay. It takes a fair amount of pressure to move them (almost exactly 5 lbs.). The only thing is is that they have over a 1/2" of play (the two that I removed) - meaning when changing direction either way, they move that much with little resistance.
Does anyone know off-hand if that sounds correct?
Thanks.
Washer Repair
