AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Can I get a better agitator for Maytag top-loader?
Joined: 11/30/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: west
Maytag washing machine with a smooth tub and agitator. When running, the agitator does it's thing and the clothes essentially sit there and barely move. A truly horrible machine. I frequently remove clothes after a normal cycle that are completely dry. They just surfed on the top of the load. If I dump detergent on the clothes instead of using the dispenser, the detergent will still be there after a complete cycle. Washer claims it has "low water usage" and less wear and tear on clothes. It achieves that by not disturbing the clothes with water or agitation.
Is it possible to replace the agitator or tub or both with an old-style agitator with fins or spirals -- something that actually agitates?
Joined: 12/9/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: COLORADO
I got the same issue so I am looking to find what part that need to be replaced.
No part available . . . these new machines are what they are. They look like standard washing machines from the outside but that's where it ends. Good luck
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
The problem is not the agitator but the lack of water used. In most all HE (high efficiency) washers they use very little water. We have a similar model and we use the (bulky or deep water or bedding) setting whichever yours has. It fills the tub much deeper with water, the clothes then will agitate. I've always maintained that more water cleans better than more detergent.
Washer Repair
