Joined: 10/25/2019(UTC) Posts: 0  Location: tennessee
I have a Kenmore electric dryer, model #110.60952990. When I push the start button the dryer starts but as soon as I release it it stops. If I hold the button in the dryer runs, drum turns and there's heat. I've replaced the switch, the motor relay and the timer assembly and still same result. Any thoughts on what else to check or could be wrong?
