Joined: 10/21/2019(UTC) Posts: 0  Location: buffalo NY
When the washer comes to the end of a cycle it will beep three times as if it’s going to shut off and then the door lock light flashes and it sounds like the motor is just churning. If I unplug for about 10-15 minutes it will reset and be ok a few loads. Then it does the same thing again
