Armenia
#1 Posted : Wednesday, October 2, 2019 5:36:22 PM(UTC)
Armenia
I have a Kenmore washer model number: 11024732300. This washer has been in storage for two years. It worked fine when I put it in storage. I recently got it out and tried to wash a load. It fills, agitates and drains fine but it will not spin out. I have replaced the coupling and the clutch. I have also pulled the transmission out and when I put it on the spin cycle the transmission is spinning. This leads me to think the tub is stuck or something is holding it. What is under the tub that could keep it from spinning when the transmission is trying to turn it? I know there is a break under there, but is there anything else? I think something seized up because it set for two years without being used.
