I purchased a diffuser P/N WPW10151374 which is the correct part called for in a KA model# KSRG22FKSS04.
The section of the diffuser which is to go through the divider is too large to fit in place.
Compared to the old diffuser, the new one is approximately 1/4" larger in both dimensions. This has caused the repair to be impossible to complete.
Typically, the mfgr is absolutely no help.
Has anyone else run across this problem? If so, what were you able to do to rectify it?
