flipngrip
#1 Posted : Monday, August 19, 2019 5:13:36 AM(UTC)
flipngrip
United States
Hello,
In the past few months have been noticing water pooling slowly over time at the base inside of the fridge.
I had thawed the fridge and then removed the inside cover exposing the coil and noticed quite a bit of frost and ice that may have been the issue.
If the drain was blocked thawing should've resolved the issue.
Although now as the fridge has been put back into operation the leak is still occurring.
What would you all advise next steps? Replace the drain pan? Is the coil leaking at a location that is creating all the frost seen in the picture? I am not sure if that amount is normal.
Thank you for having a look! Trying to troubleshoot on my own here and do what I can without replacing or hiring repair service if this is simple fix I can manage.
You can view photos here: https://1drv.ms/u/s!AjxaIa4ZXWMCkzQahuNpH2eLpGH_?e=dTUIwT
