headingsouth
#1 Posted : Sunday, July 28, 2019 5:48:31 AM(UTC)
headingsouth
United States
U-Line Outdoor Refrigerator. Model # 2175RSOD-00; 9 Years Old
Issue: Unit cools down and works for a variable amount of time (i.e. 10 -20 hours with inside temperature getting down to 38 degrees). Refrigerator stays powered (LED temp display and inside light works), but fan and compressor are off, evaporator assembly metal plate goes from frost to wet and temperature rises to 60 degrees with high humidity. No error message shows on LED screen.
Approximately 4 – 8 hours later, fan, compressor come back on and cools down fine, evaporator assembly metal plate gets frosty again and temperatures get below 40 degrees.
Actions Taken To Date:
• Repair company replaced evaporator assembly, dryer, thermistor and door gaskets
• Condensor coils cleaned
What should be tried next:
• Overload for Compressor?
• Relay for Compressor ?
