Joined: 6/18/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: brentfield
My Washer was making a real loud noise only on spin cycle, all other cycles were working well with no noise. After I spoke to a Tech. on chat he said that it was prob. the Tub Seal. So I purchase the Tub Seal and a spanner wrench instead of using a pipe wrench was much easier with the spanner more torch. I did replace the snubber ring, water drain pump and the Thrust bearing kit before the Tub Seal after replacing the Tub Seal the loud noise went away completely, the suspension spring were kind of hard reinstalling you need some muscles for it. The videos are real good. Thank you Appliance Parts Pros. for the Videos. Edited by user Monday, July 8, 2019 3:15:17 PM(UTC)
| Reason: Not specified
