You have been a member since:: 6/10/2019(UTC) Posts: 0 Location: Home
About 2 weeks ago the waterside of my dual water inlet valve stopped working. For what ever reason the ice side still seemed to work. I thought this would be an easy fixed and purchased the Dual Water Inlet Valve Kit here, and everything worked perfectly for about a week. Now it seems like I having a similar problem again, still making ice but no water. When I try to get water or ice from door, nothing come out. Is this something in the door that tells the valve to turn on? Edited by user Monday, June 10, 2019 3:32:04 PM(UTC)
| Reason: Not specified
