I have a whirlpool duet and finding this leak has been frustrating. I have replaced the tub bellows, interior bellows clamp, pump, drive belt and level hose (it was wearing through). Still it leaks quite a bit of water during the final spin. It is evident in the middle front of the concrete counter weight when the lower panel is off but I can't find the source. The left side, as you look at the washer front, has some moisture on the counter weight as if indicating it is coming from that side but i cannot find where this is starting. Any guidance would be appreciated.
