nkaufman1
#1 Posted : Tuesday, May 14, 2019 1:50:41 AM(UTC)
nkaufman1
United States
Hello,
Recently Whirlpool dishwasher started leaking from bottom center, after I took off the bottom panel, I could see water dripping from the center.
After a couple of days, I took of the filter that was all clogged, cleaned it up and put it back.
Now no leak. But am wondering why would the unit leak at all even if filter got clogged. Since the unit is still under warranty, should I have someone come and take a look and replace a seal or two that shouldn't have allowed the leak?
Thanks,
