Anyone else have this problem? The washer when the power is turned on will come on and then display this code before any cycle is chosen. I tried to turn on the washer and then immediately start the cycle and it filled for 3 seconds and then put up the code again and will not start. The code is supposed to indicate that the washer has not filled high enough, but the water is not even allowed to fill, before the error comes on.
