Hello! I'm way out of my element with this! I use the washer but have never needed to fix anything! Doo for the past year, I have been waiting on landlord getting plumber here to fix where the washer drains. I was having to connect the hose to a pool noodle and run it out of a window! I thought it just didn't have the umph to push the water up and out the window? Well, plumber fixed it yesterday (whoo-hoo!) I went to do a load and same problem! Even if I put it on a rinse/spin or a drain/spin cycle, the clothes are still soaking wet! Help! I just want clean clothes! What's my first step? I read somewhere about checking codes? I am clueless!
