hi i have a bosch KAN58A40 side by side and need to install a new water line from under the dor to the dispenser panel, problem is i cant get the dispenser panel out , i take the besel out and all the the rest of the dispenser panel but the back parte of the panel does not com out, its stuck glued to the expansive foam from the door. and i dont have access to the water line of the panel.
