Lynnylove01
#1 Posted : Wednesday, March 13, 2019 7:45:54 AM(UTC)
Lynnylove01
United States
I have an old whirlpool compactor i saved from old house that tore down. Got it home and plugged in . On start goes down but then freezes. After a while or if i turn wheel a little thwn on start will come back up. Motot is trying to reverse at boottom but then just wont. Gears and all look good can. When i put a log on bottom for it to hit appears to reverse fine but wont reverse without something in bottom. Since it just wines and stops then i can get it to go up again cant see or figure out what is not working? Advice?
WestaCay
#2 Posted : Monday, August 12, 2019 1:04:14 AM(UTC)
WestaCay
United States
Hi, I had the same problem, in a few days it stopped even make any sounds. I found out that it would cost me $72 wirh two details and work, so I just googled and odered one from amazon, non-electric. $100 and I'm glad I did.
I'll send you a link on the article I've found if I find the saved link
Let me know how your story ended
WestaCay
#3 Posted : Monday, August 12, 2019 10:03:29 PM(UTC)
WestaCay
United States
Luckily I found it! https://pickadvisor.org/best-trash-compactors/
There are few great model, but prieces range, so check them before deciding
I own the 3rd btw
Edited by user Monday, August 12, 2019 10:04:41 PM(UTC)  | Reason: Not specified
