dbdata
#1 Posted : Friday, February 15, 2019 7:19:50 AM(UTC)
dbdata
I can't find anything in the literature on this oven having beep codes but it clearly does have them. I have been having problems for the last month with the oven not keeping temperature -- perhaps I set it for 350 'bake' and the temperature gets to 170 and stops/turns off. Another time I turn it to 400 and at it gets to 250 and maintains that. These occurrences will coincide with a set of beeps.
Today I set a 3:00 hour self cleaning cycle. The door locked, the cycle started and after two minutes the oven beeped 3 times (pause) 5 times (pause) and repeated for about a minute. At the same time a little icon on the panel -- at the very LEFT edge of the panel on the center line (same as the main time digits) but I can't make it out.
My gut reaction to to just buy the two boards that are housed in the console and just 'shotgun' the repair but then if it turns out to just be a sensor I've wasted the time AND the money.
Can anyone shed light on this?
