bluefitness
#1 Posted : Monday, February 11, 2019 5:57:16 PM(UTC)
bluefitness
GE water cooler/heater GXCF05D
I've had this cooler for a while. It just started making a boiling noise and popping sound. I was thinking that air might be in the reservoir or it is overheating. Does anyone know how to purge the air from the system or tell me what are some possible causes. I used to work in HVAC, so I know how to use a meter if I need to check temperature safeties or the thermostat.
If anyone has a wiring diagram or service manual, that would help a lot.
Edited by user Monday, February 11, 2019 5:58:05 PM(UTC)  | Reason: Not specified
