Hello,
I have a Samsung DV45H7000ew/a2 dryer and it will not stop tumbling unless i either unplug the device or open the door. I can run a cycle and it does heat and what not but once the cycle is done the unit turns off like normal but keeps spinning until I open the door or unplug it.
I have read that it is the main control panel? Which i believe is part number DC92-01626B. Has anyone seen this before? Does that sound like its the board that needs to be replaced?
Thank you for your help!
