I have a wall mounted GE double oven. I have had an issue with the lower oven. When I turn it on and try to set a temperature it shuts itself off after a few moments. There is no error message. The upper oven works perfectly fine. I have replaced the heating elements in the lower oven. Edited by user Wednesday, February 6, 2019 11:58:38 AM(UTC)
| Reason: Not specified
