rpcole
#1 Posted : Wednesday, January 30, 2019 3:42:59 PM(UTC)
rpcole
You have been a member since:: 1/30/2019(UTC)
United States
The dreaded F dl error code
Believe I have searched every forum with no success.
Done the remove power, power up after 1 and 24 hours.
Have replaced the door latch, the error code.
Replaced the CCU unit, error code.
Cleaned all the connectors with CRC QD Electronic Cleaner, the error code.
Diagnostics will only run to the first step: C:00 Door Lock
At a loss for anything else to check on this machine
Any suggestions, except picking it up ~ 2" and dropping it - I did see this somewhere, would be massively appreciated
Thanks,
rpcole
