krkeegan
#1 Posted : Monday, January 28, 2019 9:29:23 AM(UTC)
krkeegan
I have a 6 burner viking stove that is 10+ years old. Last night I noticed that all of the burners appear to be too high and are much more yellow than I would like. Prior to this, the burners were all calibrated correctly with stable blue flames.
Each burner has its own air intake mixing port, so I doubt they would all become mis-calibrated at once.
The flames also seem too high and lacking sufficient oxygen. Even turning down the value, the yellow flames don't go away until the flame is nearly out.
I have never seen this behavior before. But my guess is that the pressure regulator is broken or stuck open.
Is a broken regulator the proper diagnosis of this?
Are regulators repairable, maybe there is just debris in there?
Or should I just replace the whole regulator?
