The WPW10705575 turbidity sensor leaked onto the wire connector resulting in severe corrosion of the pins. Does anyone know what the part number is for this connector?
If I cannot find one I will solder the wires directly to the sensor as the only other solution I see is to buy a complete harness for ~$100.
The connector has 6 pins with 6 yellow wires attached.
