LG frig LFD25860ST with french doors and freezer drawer on bottom. Small water leak comes through freezer compartment light switch opening and freezes solid keeping light switch closed. Ice maker quit working. No evidence of external or other internal water leaks so appears to be between the bottom and top compartments. Clean ice off switch and takes overnight to buildup again. Water dispenser in door works fine. What could be the cause of the leak?
