Condenser coils cleaned ,spotless,replaced freezer control.removed rear panel in freezer compartment and the coils are clean and shiny,the fan runs all the time dries out the ice cubes.if I turn the defroster control to the click it stops the fridge from running,then runs out and it starts running again.As there was no ice buildup on the freezer coils .however when the cover we replaced it became very cold,switched on the defrost control,when the fridge stopped and went into defrost the rear panel did not become warm..could it mean the heater is not working,could be defective or could it mean the defrost control is defective. I give up. Ed
