Hey all, Unfortunately I am stumped having only gotten so far in trying to get the water tube replaced. Allow me to explain......... About a week ago the unit started leaking the freezer door and it turns out that the water tube snapped off the bottom of the door.  I found a replacement tube and proceeded to remove the display panel.  Once the panel is off, I was able to get the dispenser unit off too.  But now I am stumped. The tube I need to replace is right there as you can see but I have no idea how to get to it. Is it just that? Should I just pull it out? Or do I have to remove something or another panel to get to the rest of it?   Thanks in advance! Helm Edited by user Sunday, January 6, 2019 7:06:12 AM(UTC)
| Reason: Not specified
