I got a broken wine fridge from a neighbor. Danby DWC283BLS. I have successfully determined the start relay is bad, and bypassed it using jumpers and the fridge works perfect. I found the relay is a QP2-4.7 from this url: http://www.reliableparts...C283BLS/PARTS%20LIST.pdfSo I ordered this part from amazon: https://www.amazon.com/g...00_s00?ie=UTF8&psc=1It looks a bit different but I from my understanding it will work (correct?) However, in the process I think I damaged the overload also (it broke near in two, so I bent some of the prongs so it stays together again. I think it would allow the compressor to work, but afraid the overload protection is no longer dependable. I am looking to replace, but am having a hard time finding the correct part. I can find similar looking ones on amazon pretty easy, but not sure if any one that looks like it will work, or there are subtle differences? See example URls here: https://www.amazon.com/d...a-11e9-b54d-a3f4d08ced8for https://www.amazon.com/d...a-11e9-ade5-fb19e6f8bfdd Can anyone help me identify the overload part I need to by? Thanks!
