BishopTango
#1 Posted : Monday, December 17, 2018 12:48:56 PM(UTC)
BishopTango
We have an LG DLEX3670W dryer. It's probably four or five years old.
We've moved into a new house about a year ago. I had to rewire the dryer for a three wire cable. It has worked properly for much of the time. There were at least a couple instances over the last year where the dryer would not power on. I would unplug it, give it a few minutes, then plug it back in and it would be fine.
On one occasion, the dryer wouldn't power on, but if you ran your hands around the metal door front, you could definitely tell some kind of energizing. It didn't shock, but if you moved your hand, it was uncomfortable. Again, after unplugging and leaving it for a while, the problem went away. That was months ago.
Now, the dryer powers fine but won't heat. I opened it up, checked the thermal fuse and heating elements for continuity and both were fine. So now I'm going to check the power cord.
One question... when I have the top off of the dryer and I'm looking at the wiring harness area back near the power cord, from the same general cluster of wires taped together, there is a white wire that is going to the green ground screw, but there is a green and yellow cable that is just loose and not connected to anything. The hole in the mounting eye at the end of the cable is also smaller than the grounding screw that the white wire is fastened to.
Should that green and yellow cable be connected to anything? Other than checking continuity on the power cable connections, any other ideas?
BishopTango
#2 Posted : Tuesday, December 18, 2018 6:20:20 PM(UTC)
BishopTango
I checked the power cable connections on the dryer for continuity, everything was good. I plugged the dryer in sitting on the ground (to test before stacking again) and got hot air. We unplugged. Stacked. And then subsequently only got cold air again.
I ran through all of LG's heat tests, and no error codes of any kind come up, which they say means a power issue. I unplugged the dryer cable again and opened up the dryer outlet to test there and everything comes up right. 240v hot to hot, 120 either hot to neutral (3 wire setup).
I plugged the dryer back in again, tested, and got heat. I have no explanation for it.
