Joined: 12/15/2018(UTC) Posts: 0  Location: Miami, Fl
Maytag Bravos XL Dryer doesn't start. Lights on panel turn on, no error codes, when I press start I get a ding dong sound and it doesn't start. Checked that door contact is working, connection inside lid is connected, exhaust line is clear. Recently changed out the high temp fuse. Worked for a couple drying cycles then stopped working.
Any ideas, suggestions???
Thanks in advance
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The lights are just blinking, everything is on ,when you touch it to turn on the estimatedtimer just blink,but nothing comes on
Joined: 12/4/2022(UTC) Posts: 0  Was thanked: 1 time(s) in 1 post(s)
have you tried resetting the dryer or read any error code?
