Joined: 12/9/2018(UTC) Posts: 0  Location: West Virginia
I have a Whirlpool Duet Model #WED9470WW1 that as of today will no longer turn on (as in nothing happens at all when pressing the power button). It was working fine earlier with a small load, but come to swap it out for another I found that it would not turn back on.
I flipped the breaker for the dryer and the house to see if that would help, and I also opened the top panel to see if any connections came lose, but nothing seemed amiss. Took the front panel out to check as well, nothing loose. It seems to be getting some sort of power, as when I unplug and replug the dryer back into the wall I can make out a small click sound coming from it. Otherwise, no lights or anything to indicate it is on.
Any idea of what to look out for? I figure something may have just shorted out in the dryer.
