tedshred
#1 Posted : Wednesday, November 28, 2018 3:13:36 PM(UTC)
tedshred
While looking for a leak (yes, the bellows has a hole) I pulled the lower front panel.
One of the wires coming off the rear safety switch (back right bottom corner) is lying loose, just under the motor, almost dead center of the floor of the cabinet.
No exposed copper, looks like may have broken from a connector, but I can't see anything obvious.
I taped the front limit switch down to run the washer while I looked for the leak. Turns out the washer will run in either position...maybe the loose wire/open circuit is allowing it to run?
Any insight? I'd like to put it back where it belongs before I button it up.
Ted
tedshred
#2 Posted : Thursday, November 29, 2018 6:03:27 PM(UTC)
tedshred
couple pix
UserPostedImage
UserPostedImage
UserPostedImage
