Bravos XL Model MVWB980BW0 clicking noise recently started after retightening the bottom nut on the shaft which had loosened. The noise appears to be coming from the motor. It resembles the sound of a pebble between the stator and rotor. However, I have cleaned and inspected that area and found nothing.
Originally Posted by: jeff.shields1  Bravos XL Model MVWB980BW0 clicking noise recently started after retightening the bottom nut on the shaft which had loosened. The noise appears to be coming from the motor. It resembles the sound of a pebble between the stator and rotor. However, I have cleaned and inspected that area and found nothing. I am having the same issue. Any thoughts or updates on what this was or could be?
