Joined: 11/11/2018(UTC) Posts: 0  Location: MA Thanks: 1 times
Kenmore Dishwasher model 665.12783K311 runs thru wash cycle then hangs up in rinse where it rinses for a few seconds, stops, and rinses again for a few seconds, stops - continues this loop until CANCEL button is pushed. Have replaced the control module with no change in operation. Any idea what may have failed?
Thanks OHM - confirmed my suspicion that the fan failed where I have seen moisture exiting from a small door “vent” near the fan assembly during the dry cycle. I have disconnected the fan and the machine continued thru the cycle it had been hung up. Thanks for the vent assy part number also.
Thank you, I thought that impossible to find the answer for this problem.... Edited by user Sunday, December 2, 2018 10:43:32 AM(UTC)
| Reason: Not specified |
