I have a Whirlpool top freezer, model number WRT311FZDW00. This is in a business setting. We recently moved to a new building where we have access to an ice maker hook up. This fridge came with an ice maker back when it was purchased a couple of years ago, but we never took it out of the box. I went to hook it up today and noticed that the connector is not correct. This is not the correct ice maker. Our Whirlpool fridge has an 8 pin connector, and the ice maker has a 4 pin. Strangely the plastic cover has the spot for the 4 pin connector. The fridge was purchased from Best Buy, but I doubt they would work with us since we have had it several years now. I have tried searching around for the correct ice maker or a converter wiring harness without success. Can anyone give me some advice on how to go forward? Thanks everyone! Edited by user Wednesday, October 31, 2018 1:45:09 PM(UTC)
| Reason: Not specified
