AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Frigidaire Gas Dryer Shuts Off After Less Than A Minute Run Time
I have a 9 year old Frigidaire gas dryer. Model LGQ1452KS0. It will run anywhere from 30 seconds to 5 minutes and keep kicking off and causing all of the lights to flash. It starts right back up and will run again for a short amount of time. Suggestions on where to start troubleshooting. It does this on heat or no heat and also on automatic or timed drying.
Originally Posted by: hooter726  I have a 9 year old Frigidaire gas dryer. Model LGQ1452KS0. It will run anywhere from 30 seconds to 5 minutes and keep kicking off and causing all of the lights to flash. It starts right back up and will run again for a short amount of time. Suggestions on where to start troubleshooting. It does this on heat or no heat and also on automatic or timed drying. Try cleaning out you vents
Dryer Repair
