andover02
#1 Posted : Thursday, October 4, 2018 1:26:24 PM(UTC)
andover02
Hi, I found this forum very useful.
I would like to ask your help to identify and fix the problem.
The KitchenAid KUWS24RSBS00 model has been working very well. However, recently it seemed to be malfunctional. Here are the symptoms.
1. When it operates - fan running and I can hear the working sound, the temp goes down to 48F (upper) and 52F (lower).
2. Once it stops, the temp is slowly going higher - sometimes it is up to 78F / 78F.
3. When I turned the temperature control knob to the colder temp position, it operates and the temp is down to 48F but again when the operation stops, the temp goes up.
Would you please advise me any suggestion?
I thank you in advance for your kind assistance.
