Tareef
#1 Posted : Monday, October 1, 2018 11:07:54 AM(UTC)
Tareef
My Samsung dryer stopped working all of the sudden. When I press the power button nothing happens, no lights no noises.
Power in the outlet is fine. I opened the dryer door, no light. I pressed the start button and it did not work (just to make sure it is not a lights issue on the front panel only). I unplugged the motor relay plug on the control board and checked between the black and brown wire and it read 120VAC. I checked the 2 thermal switches at the blower and heat source and both are not open. I also checked the thermistor and it read about 10K ohms at room temp. Any thoughts?
