I have a Creda Stove Top, 5 glass gas burner. The two Igniter Switches have cracks in the plastic, dont work. When I have the unit plugged in, all 5 igniters go off at the same time, don't turn off. Only when I turn on burner 1 and 3, then igniters turn off. Both igniter switches (AP5629155) need to be replaced. How do I take apart this Stove Top, step by step, to get to the switches, behind the knobs on top? They wont come out by the top, need to take unit out. There are two small clamp/clips at bottom. What tool is needed to remove them? Please advise.
