Hi, my frigidaire gallery double oven range started acting up.. when using the top oven, it heats up fine, but when I open the door, the display stops displaying the oven temp and displays "d-0" instead.
If I cancel the oven heating, and start over, it's fine again until I open the oven door again, and it shows d-0 again until I cancel the oven heating.
Any thoughts on the problem?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Mine just started the same thing. I sure would like some advice on that.
