AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Ge washer agitates, drains, sounds like it is trying to spin but doesn't
https://youtu.be/dzBB2irBI3IThe video explains it all. It's short. Looks like the shaft is spinning but the belt/tub isn't following. Smells like burnt rubber down there.
Okay, so I replaced the clutch down there. But something weird is happening, or not and I just don't know how these things work. But the hub and spindle spin on the drain cycle, but not the pulley then the belt also. The install of the clutch is pretty straight forward. https://youtu.be/fixp-6-qiGcPlease take a look, anyone out there and see if you can identify the problem here. Thanks
Washer Repair
